DOUGs Web Site
Sling 2
2 - Miscs fuselage brackets
I installed the two safety harness brackets behind the seats and the controls stops on the aft spar with clecos. The lower control brackets will need rivets drilled out to install.
safety belt mounts clecod
control stops clecod
need to remove rivets
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
