Brief Description: 3 - Bracket riveting and console panels
I matched drilled and riveted the top rail to the firewall brackets. I left the outside skin mounting angle (bottom of top rail) unriveted except the last hole at the firewall. This piece will need to be faired with the skin and then redrilled and riveted to keep an even contact with the skin.
I also riveted the inside skin mounting brackets to the uprights, pealed the plastic film off most of the console parts, and test fit the throttle bracket.
