Brief Description: Welded rudder lower hinge bushing
To hold the hinge bushing while tack welding, I drilled a tight perpendicular hole in a piece of wood. The bushing was then inserted to the proper depth and checked for square. The part was then welded. Afterwards the bushing was reamed up to .3750 dia
