Continued work on the horizontal tail. Built extensions for the fiberglass tips to mount on. I like to pop rivet fiberglass instead of just gluing (scotch weld) so I also drilled them for 3/32 pop rivets. today, I continued riveting and closed out the top of the stabilizer. Most of the rivets are easy to get to except the ones that are close to the hinges. I had to modify a bucking bar to get in close enough
