Andrews Web Site
Date:  4-10-2011
Number of Hours:  6.00
Brief Description:  Hinge brackets
Made the rest of the hinge brackets. I formed the bends on my press brake. Since the thickness of the steel is .063, I needed a bigger bend radius than I have on the brake. I simply bent a peice of .040 aluminum first then used the aluminum as a nose piece on the brake. After spring back, this gave me a radius of about 3 t.
Outboard brackets completed.  Inbd bent
All Hinge Brackets Complete
Started to lay out the aft Horizontal Tail Spar
