I noticed that building the tunnel on the bottom of the fuselage (the next step) was going to interfere with the assembly fixture. As a result, I changed the way the firewall bulkhead is supported. It used to be supported at the bottom, but now is on the tip. The engine mount is still installed and is constantly used to ensure the proper Zero and 1.5 degree engine angles are maintained.
