Andrews Web Site
Date:  5-4-2023
Number of Hours:  8.00
Brief Description:  Final sealing of left wing tank
This is the final day of the sealing process for the left-wing tank. The wing was removed for access to the inboard end. Image 1 shows the view looking in from the inboard rib. It shows very good sealant squeeze out all around the rib leading edge. This interface will now be coated with an additional layer of brush-on sealant. Image 2 shows more of the interface before the final brush coat as seen through the access hole. Image 3 shows everything with external brush coat. Sealing complete. (except for access cover)
You can see sealant sqeezing out around rib tip
Showing sealant squeeze out around intermediate spar
Sealant applied to outer surface
