Andrews Web Site
Date: 2-14-2023
Number of Hours: 8.00
Brief Description: Inboard (stub) wing section
(Note: There have been some delays in getting progress on the Nexus since my RV-4 annual inspection was due and it took a lot of work this year.)
Working Nexus inner wing root details. I cut out some blanks for the upper skin on the root as shown in image 1. I should know better by now, but I need to be more careful when I use the dimensions that are on the plans. Turns out, the length of the skin is not quite long enough, it needs about 2 more inches than depicted on the plans, so the skins shown in image 1 are scrap. Meanwhile, I also started working on the upper skin. This requires bending as needed to match the inner ribs and to meet flush with the outboard wing panel. Based on what I am seeing with the first panel (right wing) this will not be as hard as feared. However, before I commit to drilling the holes and anchoring the skin, I am going back and completing the final drilling, debur and riveting of the inboard substructure. I also completed the riveting of any fuselage rivets that will be inaccessible after the inboard ribs are installed. Having said that, I did not rivet the floorboard skins that have rivets through the fuselage side panels. These rivets will be a challenge to access in the future, but I cannot close the fuselage with these panels before substantial work that is needed on the control systems.
Newly made scrap metal
Starting forward skin fitting
Cleaning up rivets in inaccessible areas
