Garys Web Site
Date:  7-25-2012
Manual Reference:  Pg 165 thru 178
Brief Description:  Front Stabilizer V & H Mounts and Rudder
Prepared rudder horn and installed. Top rudder mount also installed.
Front Horizontal mount installed. Note that M912 is different from manual. Bolt supplied is not drilled in shank. Used drilled shank bolt because there is no way to check status once stabilizer is mounted. (Picture #2)
Front vertical stabilizer mount safety wired after check fit.
Blind Spot
Blind Spot
