Garys Web Site
Date:  7-27-2012
Manual Reference:  Pg 165 thru 181
Brief Description:  Horizontal Stabilizer to Rear Keel
Stabilizers mount tube was 4.8 degrees both sides. Book say’s 5 degrees. Next I set up to install the horizontal stabilizer. Next I used and old cable cleave for a guide for the positioning lights. Padded and height adjustable shop chair to make it easy to guide stabilizer onto mount tube on rear keel.
Note: Before installation I set in place and predrilled the plastic inserts in the stabilizers that go onto mount tube at keel. Use bolt to hold its position as I guided stabilizers onto mount tube. Picture #2 red circle of position of plastic insert in stabilizer.
Very happy with the fit to the front and rear mounts both sides.
4.8 on Both Sides & LeL Keel
Plastic insert location
