Garys Web Site
Date:  7-21-2012
Manual Reference:  Pg 166 thru 182
Brief Description:  Horizontal Stabilizer Rubber Trim
The rubber trims on horzontal stabilizers has been on temporarily for several days so trim will take shape of the tight turns spots. Gel type super glue used ever inch except for hard to form to spots. (Wrinkles, rivets and sharp turns.) Note: Started gluing form trailing edge and did cut excess until final 6 inches.
Let glue cure for a day and check for loose spots. Did not find any so I trim the rubber with knife where brackets are located in picture #3 and picture #1. Bracket in hand and not mounted to keel yet helps make for snug fit.
Note: Old manual say’s stabilizers are identical with no left or right. The M912 model does have left and right sides.
Trim Rubber
Trim Rubber
Nice Job
Nice Job
Trim for Bracket & Extra Glue
