Worked on the front covers that are so new the instructions are not out. The aft cover is removeable so you can get at the stick by removing its cover. The front is riveted to the floorpan and goes against a tube. The other side is not in because it covers up the fuel valve and makes access almost imossible. I ordered some metal from ACS and will design a new aft cover that extends past the fuel valve and then picks up the supplied front cover.
Put in all the nutplates under the floorboard. I can't imagine myself doing nutplates with pop rivets, but tried it and loved it!
Put the pulleys in at station 7 and ran the rudder cables up front.
