Brief Description: Decals, panel final, motor ground
Completed intalling the decals on the panel and aircraft interior. Put Experimental sign across the rear panel, visable to people getting into the aircraft.
Screwed on the panel with all the screws. One screw sheared off, just my luck. Fixed. Installed the instruments again and tested, all worked as expected. Looks like the interior is finished for the motor run and almost for flight. Came out much better than I expected. The Zolatone finish is clean, simple and attratcive. The Flightline Interior seats and stuff with the Aerosport overhead and center console and side panels finish it off.
Built the second engine/motor mount ground and installed it. Back to the firewall forward for a final check and some minor jobs.
