Brief Description: Spinner, check FWF, cowl final fitting
Went over all the nuts, bolts, clamps, screws, hose fittings and other things firewall forward. Found one screw slightly loose, not bad! It is ready to run/fly.
Put on spinner with final screws. Need to safety prop but it will wait until the motor runs.
Started fitting the rear of the upper cowl camlocks. Need to adjust the receptacles to the proper depth and add aluminum tape to the top of the recepecle mounts so the cowl is flush with the skin.
