Brief Description: Baffles, air hoses, governor, etc.
Put tie rods on the baffles. Quite a challange on one, the rest were just hard.
Installed SCAT lines between baffles and heat boxes. Built two supports for the SCAT tubing and glued baffle seal to a portion that is near a fuel line.
Safety wired the governor screws now that the prop control is hooked up and the lever arm needs no further adjustment. Put a clamp on the Light Spped wires where they go into the baffles.
