Conmpleted installing plenum hinges on baffles. Trial fit and it still goes, somewhat hard to get the pin in the left side, but it goes. Put threescrews in the governor baffle, a bit of a challange. Ended up tapping the nutplates from the bottom and then using a star washer on the screws. Put on nutplates where the plenum bolts to the baffle up front. I think I am almost out of #8 nutplates, hard to believe.
Hooked up governor control, works well and smoothly. Put Aerosport motor mount covers in place with a touch of silicon to seal. Put on the Light Speed iginiton coil wire penetrator on the baffle. Installed the 4" line to the oil cooler.
Looking for a gray gasket sealer high temperature stuffto seal the gaps between the motor and the baffles. Will need a lot.
