Bruces Web Site
Date: 12-4-2013
Number of Hours: 5.00
Brief Description: Wire run brackets, Light Speed pickup, starter cab
Checked cowl oil door which maintained it shape when weighted down and the epoxy cured. It fits very well. Finish later
Made six brackets to be attached to the oil pan bolts and support the EGT, CHT, starter cable, alternator wires, etc. Installed the ones on the left side of the motor.
Figured out the wire run for the Light Speed pickup. Removed the pickup, routed its wire and reinstalled the sensor, verified centering and gap to magnet ring. Built two brackets to hold the wire, one shown in photo 3.
Made up the starter #2 cable. Soldered both ends on and put in. Installed cable clamps to hold it in place and still have movement to deal with the motor jumping around. Disconnected and taped at the starter, don't want an inadvertant prop spin!
