Brief Description: EGT, CHT probes, left side exhaust, wire runs
Started on exhaust system left side. Drilled for EGTs and installed one pipe at a time while running the EGT and CHT probe wires and putting on clamps. Got it all in. The wires will terminate on the vertical motor mount tube just behind the motor. See photo 2 and you can just see the wire runs with the bunch in photo 2 to the right.
Put the Light Speed sensor wire inside a hard plastic tube and anchored it to the motor behind the starter.
Got my #8 alternator cable from ACS. Put lug on one end and started running the right side wires which consist of alternator power and field, mag, oil temp and all right EGT and CHTs. Put two clamps after tying the wires.
