Brief Description: Plenum oil filler isolator, air filter
Fit oil filler isolator box onto engine, put bondo on top and set the plenum on so it was in the correct place. Glassed it with 2 layers of carbon fiber. Can cut out the opening seen as a shallow depression on the box in photo 2 and it should slide right over the oil filler. Some baffle material inside the box and the oil filler is available thru the door int he cowl top.
Removed the aluminum recess on the air filter where the mixture lever is located and built up a form on the inside with foam and glassed. Better than the aluminum, a rare admission for me.
