Brief Description: Front baffles, Light Speed pickup
Continued with the front baffles. Completed to the point where I need the cowling on to be sure it is lined up right. That requires the flywheel which is on its way back from Light Speed and the prop and spinner. Tomorrow finish up the spinner.
Drilled and tapped two 8/32 holes in the seal retainer lugs to mount the Light Speed magnet pickup. Installed with star washers, locktight and safety wire. Don't want this to come loose!
