Finished fitting up the right wheel fairing. Mixed flox and put it on. Came out to within 1/8", however since you can't really locate the front cenerline to within 1/4", I should say it came out close. Floxed in the left 1/4" bolt/washer and did some patching on the forward piece flox.
Trimmed the leg fairings to shape and size. Started drilling in the hinge. I am almost out of reduce head nutplate rivets, hope there are enough for these. More are on order.
The stand that the fues is sitting on has a 2X4 that interferes with the left leg fairing. Will have to lower the platform and move it back slightly. That will most likely change my centerline smap line. Oh well, it was going smoothly.
