Removed both wheel fairings and added some flox to a couple of points where it was needed to anchor in the pant. Put them back on again.
Completed the hinges on both leg fairings. Had to cut down the nutplate rivets I used on the thin fiberglass, but had just enough. No more nutplates til the order arrives.
Had to lower the aircraft to the ground to move the lift platform back about 12" to let the upper fairings go on. Put in the steps to provide a way to align the leg fairings.
Put release tape on the left pant, leg fairing and installed. Put the fairings on.
