Bruces Web Site
Date:  4-26-2013
Number of Hours:  4.00
Brief Description:  Modify center tunnel cover, mount console
Modified center console cover. Cut new joint just in front of the center console so now I can remove the front part to gain access to the fuel pump/filter/flowmeter and the rear part to get to the flap actuator without removeing the center console and its jack plugs. Put in a modified cable clamp that holds the bundle of jack wires away from the rudder cable and still leaves room for the air duct. It is a bit crowded in the spar area.
Drilled mounting holes in the center console after trimming the bottom to fit better.
