Brief Description: Center console, mount pilot and passenger jacks
Trimmed tunnel top to clear wiring at the firewall and put on sleeving to protect the wire. Cut holes where the first and second tunnel top pieces meet to pass thru the two bundles of wires to the jacks.
Added nutplates to both printed circuit board jack mounts and some lables. Installed all pilot/copilot, passanger and entertainment jacks into PC mounts and bolted in the center console. Got out fuel valve to be sure it clears the center console. Need to check that the wire runs clear the rudderl cables in the tunnel, perhaps I will need a clamp on a standoff to assure that they remain clear.
