Brief Description: PAR100EX radio wire, flaps, clamps, misc.
Cut 2' off the cable to the PAR100EX radio and put the 15 pin Dsub connector on. Bolted the remote transceiver in place. Realized I need BNC connectors for the antenna so put in an order to Stein this P.M. Ran the wires to the flaps and wired the switch. Laced the wire run to the flap motor and position detector. Will install tomorrow and work on the wire runs in the tunnel.
Put a couple of clamps on wire bundles to better define wire lengths.
