Brief Description: PAR cables, Dynon Radio cables, misc wires
Re-strung the cables from the PAR100EX including the power, ground and cables to now COM1, the Dynon radio. Made the cable that will run to the Dynon radio that mounts on the left rear of the fues. Consisted of 7 wires plus a 3 and 2 conductor shielded lines to the PAR. Put the first 5' into a heat shrink white tube and shrink. Just behind the panel it converts to 6 wires that will go to a Dsub that plugs into the radio head.
Installed a couple of clamps to hold wires from the PAR and tied in the Intercom section light to the dimmer. Put the PAR and PAR intercom light grounds into one of the 37 pin Dsub ground busses.
