Bruces Web Site
Date: 4-20-2013
Number of Hours: 4.50
Brief Description: Re-do intercom harness
Decided I need to tackle the intercom harness. Since I deleted the ICOM and added the new Dynon radio, it makes no sense for the PAR100EX radio to be COM1. Also the wiring diagram shows a 3 wire shielded going to the intercom from the Dynon remote transceiver for PTT and MIC, and this was the final straw. Also the wires I specified when ordereing the harness from Stein had only 2' going to the second radio, the Dynon remote is going back in the rear near its antenna.
So, yes have the wire, oops, the plugs are Dsub miniature. Have the extra pins from the harness and yes my crimper does them just as well as regular size. No pin extractor. There is a Frys 38.7 miles from the house, so a trip up and back to get 2 right sized extractors. Picked up a few other things while there.
Took the plug apart, pulled the short wires, made new ones, 8' long and switched the COM1 and COM2 pins. Put it back together and am where I was this morning, but with things right.
