Bruces Web Site
Date:  3-28-2013
Number of Hours:  5.00
Brief Description:  Power circuits and fuse panels
Figured out the loop needed to enable the fuse boxes to fold forward to access the two system hubs. Riveted the lower instrument panel/switch panel in place.
Ran and connected up the normal power and alternate Ebus lines. Tested and it works just fine.
Put a wood beam just below the long cable run for the switches. Ran most of the wires from the fuse panel to their respective switches, connected at the fuse end only. Still need to run about 3 more and then will fix up the wires around the fuses and the loop, seen in photo 2 with tie wraps to hold them temporarly in place. Then terminate their ends at the switches. There will still be a bunch of wires in this cable run since there is only one wire at each switch.
