Brief Description: Finish fuse panel wire, one Dsub
INstalled the last wires from the fuse panels except for a misc Entertainment and headset power wire. Tied it off wit thie raps for now and tied up the service loop. Now I can pull the wires tight and connect to the switches.
Decided to wire the Skyview hub power plug. Did it and started checking connections. I had the pins backward on the connection table. Each of the many cables I have designed has a table of connections, the function and the pin number for each end. The first one assembled was wrong, perhaps a lot of work to be redone before assembly and testing.
