Completed the two terminal strip mounts and drilled holes to mount on top of the gear mounts. Actually put in a few wires on the trim TB. First of many.
Installed insulation on the side walls where the wiring will go. Still more to put in, but it can wait.
One of Stein's techs called and they are starting my PAR100EX harness. Was able to change the wire length to the remote transceiver and have them leave off the Dsub. This will go in the tunnel to behind the flap area where the transceiver will mount.
