Brief Description: Mount flap control, ADSB, Trans and T.B
Installed ADSB receiver and Transponder in the tunnel. Put flap control system in next to flap motor.
Built 2 terminal board and connector mounts that go on top of the landing gear mounts. These are for the stick wires, trim servos and autopilot servo connections. Can be easily reached with the top cover removed from the seat cover thing.
Only two things left to mount, the PAR100EX transceiver which is not here yet and the Pitot tube heater control in the wing. May actually be able to start wire tomorrow after putting in some insulation that will be blocked by wire runs. Will also wrap the front hot air vent with some insulation to protect the transponder. Looks closer in the picture that it is, but why not.
