Photo 1 is the protoype Dsub holder. Would be nice to have a punch, but the are around $500 each size, so will figure how to make a router guide to make the cutouts.
Installed my Skyview system hub and the Skyview network hub. Put on some cables and found it is relatively easy to reacy all connectors with the fuse panel rotated down. Will use nutplates on the circuit board and nuts on the network hub. My hub is designed to be upgraded as things are added to the system and may be in and out.
Built ADHARS platform and drilled it in. Not quite 2' from the battery cable, but close. Will put on the skin and see if it stiffens up like it should, now it is easy to move.
Laid out the location of the Skyview batteries. Most probably will use an angle to stiffen up the former behind the large Skyview and nutplate on the batteries.
