DAVE'S WEB SITE
Date:  5-6-2007
Number of Hours:  5.20
Brief Description:  Love the wiring
Lots more wiring and then some more wiring on top of that today. I got the txpdr hooked up and functional. I still need to create the adapter for the alt encoder. Worst case I'll cut the adapter off that's there, but I'd prefer not to so that I can retrofit add a 'real' alt encoder later if need be. I put in an additional cannon plug that is almost entirely devoted to the lower sub-panel.
I was able to add the key ignition and the ELT remote to the lower sub-panel today.
I spent a lot of time bundling wires and zip tying them together. If I forget a wire here or there I'll simply add it in, throw another zip tie on there and call it good prior to spiral wrapping everything. In fact, I'm thinking about holding off on spiral wrap until after the plane is assembled, running, and flyable in case of the need to troubleshoot.
I will need to glue the subpanel on very soon. I'm trying to hold off as long as possible on that though for obvious reasons.
