Swami's Web Site
Date:  5-24-2014
Number of Hours:  11.50
Brief Description:  Project start
0800-1930. Started in ernest. I didn't want to stop because there was a huge learning curve trying to learrn the parts, read the manual and match the manual instructions with the plans. Most diifcult part of the day is taking the snips and cut part of the front spar, per the instructions. Learned that the plans are not 100% accurate and there is some interpretation required. I made sure not to cut to much since it says to maintain minimum hole distance and there isn't a hole to measure from. I refined the snip after putting the spars, flanges together with the skin for match drilling.
