Swami's Web Site
Date:  5-26-2020
Brief Description:  FIRST ENGINE START
Ran oil sump heater for approx 60 minute. Oil temp 75 degrees at start
engine started right up.
Start at 1653Z; 67 degrees, sunny, 10 knot headwind
readings after approx 3 minutes
- RPM 2480
- Oil pressure 75 psi
- Oil temp 90 degrees at shutdown
- 3.3 GPH fuel flow
- Fuel pressure 28 psi
- CHT #1-218; #2-238; #3-228; #4-232
- EGT #1-1296; #2-RedX; #3-1111; #4- RedX
- Battery 13.1 V
- Amps 0
Noted following issues to be corrected:
- RPM appears to read 2x RPM
(PMAG research shows two pulses per rev)
- engine idle is too low. when pulled to idle, the engine died
turned idle screw one revolution
- no egt reading on #2 and #4 (EFIS shows red X, there is a low reading with engine off)
ordered new sensors to see if it is the sensor
- Amps gauge reads 0 amps
Noticed I didn't turn on Alt switch. Check on next run
- Mag check needs to be reaccomplished
