Brief Description: First turn-over of engine;check prop tip tracking
proptracks well within 1/16' limit.
drain inhibit and fill with mineral oil; chk prop track installed top plug finger tight and removed lower plugs. Turned on sump heater fro about 45 minutes prior to turning over engine.
Ran starter 4 x 10". Noted oil pressure increasing to 43 psi. Oil temp at 75 degrees
