Just pecking away at the main-ribs for the wing... these are the 0.025" ribs -- just drilled pilot holes for the lightening holes -- will use the cutter/flanger later...
Belatedly realized that I forgot the joggle on the tap that attahces to the spar web, so will have to correct the form and go back and see if I can (after the fact) put the joggle in the ribs already formed... if not, oh well, I'll just cut out a few more and use the firts ones as practice.
Typical of my geriatric building methods -- two trudging steps forward, one step sliding backwards; then do it all again...
