Starting to build the fittings for the header tank -- it is a HF 7-gallon air tank (aluminum) and will sit where the usual Cougar tank sat... using weldable fittings only they fittings will be riveted -- with Van's version of pro-seal for the sealant... ground off feet and started on first fitting. Have to curve the underside to match the tank; so far so good...
