Dan & Andrew's Web Site
Date: 12-18-2015
Number of Hours: 3.00
Brief Description: Finished Ailerons, Started On Flaps
Today I started off by installing the aileron brackets with the bolt-washer-lock nut hardware per the plans. I also applied torque seal. Next I deblued a bunch of the flap parts, deburred and finished the edges on the flap spars, labled all parts, and clecoed the ribs, spar, and bottom skins together for both R & L Flaps.
Need to make shims, spacers, and match drill next.
Installed brackets, torqued bolts/nuts, torque sealed them
scotchbriting the flap spar edges
Flaps partially clecoed together
