Tonight Wendy was suppose to help me finish the riveting on the right wing, but she promised to help me first thing in the morning instead.....I decided to work on the bottom skins. I preped one of the four skins. The inboard skins are thicker than the top skins. I deburred the edges and then fileld the corner to help the overlap of the two skin halves lay flatter. I then deburred all of the holes, but I use the angle drill with the deburring bit....much faster than doing it by hand. I then dimpled all the holes and set the nut plate for the access panel. I will break down the stands tomorrow and put the wings in the mobile cart...a definate milestone.....
Deburred, dimpled and plate nuts in place
Plate nuts in place for access panels on bottom skin of wing
