I attached the left aileron tonight. It went on very easily. I also fed the plastic conduit thru the holes in the ribs and ran a string line through it. I need to ge the landing lights ordered. I also need to figure out what auto pilot I will use so I can get the servo's attached. I also went through and torqued the tank attach bolts and added the remaining screws on the side of the tanks. I also did some research on the flap positioning system and I have pretty much decided which one I will use for Juliette.
