This morning I continued with the left aileron. I figured I can do the assembly upside down and it will still work out. The trick was to get the trailing edge holes to look decent and in line....I worked! I think it looks great. I then dis-assembled the ailerons and marked each piece with the engraver. I will begin to deburr and dimple these part next..then on the priming again
