I went to Home Depot this morning to get a few things (Acetone, scrub brush, 2 bus tubs) I also went grocery shopping.....To do the cleaning, I decided outdoors will be the place to set up, next to the garden hose, One buss tub had about an inch of PPG degreaser and dewaxer and the other tub I filled with water. The parts cleaned very easily although I had to remark everthing , because the sharpie parts notes hafd washed out. With everthing dried and remarked, I set up 2 tables inside the shop for drying the parts, It was soo hot that my goggles where filing with water. You must wear clothing to protect your arms and face. This cleaner is strong and a little got on my arm and it did burn for a while. Tomorrow I will set up the chicken wire rack to prime the parts on.
