I got a delivery form McMaster-Carr. I ordered the drill bushing I will be needed to mount the empenage elevator horns. I also got some nylon spacers and the aluminum set screw shaft collars I will be using on the brake master cylinders....at some point. I finished drilling the rivet holes into the firewall flange for the top front skin. I also need to get the center rib drilled, but I need to do it from under the skin...I will figure this out and do it tomorrow. In the mean time, I installed the AN tube fittings in the fuel valve, using the fuel lube I got in the mail yesterday. I also did some research on how I will be addressing the fuel valve indicator...I've decided to use the Van's supplied valve and will order a nicer pointer. I will also order the fuel selector plate available from Van's. This should look nice and clean. I also checked out other options, like having the mounting plate engraved, but decided against them. I also got an e-mail back from Bonaco's and they quoted the brake lines and all fittings at $170 plus shipping. I will probably go for it.
