I got my order from Aircraft Spruce today....The electric fuel pump and a tube of fuel lube....I worked on the front deck again today. I drilled in place the angle supports for the panel and match drilled all of the holes in the whole assembly. I'm not sure when I am suppose to drill the holes from the front top skin to the firewall flange, so I began to do that, also. I drew a centerline along the firewall flange and began to drill through the top skin. I got about half of the way before I decided to call it a night.
Aircraft Spruce delivery...fuel pump and fuel lube...
The two angle brackets that connect the panel to the forward deck
The front top skins are clecoed onto the firewall flange...
