Conrads X-10 Build Log
Date:  10-24-2010
Number of Hours:  1.00
Brief Description:  U-1057 A and B Wheel Fairing halves and drilled #
SECTION 48-03
10/23/2010
Step 1 ..I make the “V” shaped Wheel Fairing Holder as described in figure 1.
Step 2 … I placed the U-1057B Wheel Fairing Rear both L/R into the just made “V” shaped holder and align with the vertical. Measure ½ length of the opening and mark a center line at the top of the Wheel Fairing and extend ½ inch back.
Step 3 ... Tape with duc tape both halves of the U-1057 A and B Wheel Fairing together.
Step 4 … I drilled and clecoed the U-1057 A and B Wheel Fairing halves as specified in figure 4 using a #40 small drill bit. And then drill a 1 / 2 inch hole where described. Now I marked the Wheel Fairings left and right.
Time about 1 hour for both Wheel Fairings.
U-1057B Main Wheel Fairing  both L/R
