Conrads X-10 Build Log
Date: 11-13-2009
Number of Hours: 2.00
Manual Reference: 33 -3 Step 1 to 10
Brief Description: Section 33 BAGGAGE AREA … Page 33 -3 Steps 1 to 1
Section 33 BAGGAGE AREA … Page 33 -3 Steps 1 to 10
Step 1, This was already accomplished.
Step 2, Final-Drilled #40 the dimpled the holes in the F-10100B Baggage Door Shim and F-1026 Lower baggage Door Seal Channel in common to the F-1070-L and F-1073L Side Skins.
Step 3, Clecoed the F-1026 Lower Baggage Door Seal Channel and the F-10100B Baggage Door Shim to the F-1070-L and the F-1070-L and F-1073L Side Skins.
Step 4, Match-Drill the two holes in the bottomed-tab of the F-1026 Lower Baggage Door Channel to the F-1022A-L Baggage Floor.
Step 5, I trimmed the area off using a high speed cutting disk of the F-1031 Upper Baggage Door Seal Channel as shown in figure 3.
Step 6, Final-Drill #30 the hole in the outboard flange of the F-1031 Upper Baggage Door Seal Channel which is common to the outboard hole in the end tab of the F-1026 Lower Baggage Door Seal Channel.
Step 7, I clecoed the F-1031 Upper Baggage Door Seal Channel to the F-1006A Bulkhead and the F-1026 Lower Baggage Door Seal Channels as shown in figure 4.
Step 8, Clecoed the F-1027 Close-Out Panel to the F-1026 Lower Baggage Door Seal Channel. Step 9, Now Match-Drill #30 the holes in the lower flange of the F-1027 Close-Out Panel in to the F-1022A-L Baggage Floor.
Step 10, Final-Drill #30 the holes common to the F-1031 Upper Baggage Door Seal Channel and the F-1006A Bulkhead.
Time about 2 hours.
Baggage Floor Final Drilled
Baggahe Floor being Clecoed
