Conrads X-10 Build Log
Date: 10-28-2009
Number of Hours: 1.00
Manual Reference: 31-8 Step 8 to 15
Brief Description: Section 31 UPPER FORWARD FUSELAGE ASSEMBLY... Pag
Section 31 UPPER FORWARD FUSELAGE ASSEMBLY... Page 31-8, Step 8 to 15. Step 8, I dimpled the holes in the flanges of the F-1001A Firewall Bulkhead that are at the top in common with the fuselage skin. Step 9, I accomplished this previously I believe in chapter 29. Step 10, I removed the entire assembly and because I have already deburred the parts I skipped this step too. Step 11, Already accomplished this too. Step 12, All parts are already primed too. Step 13, The dimpling has already been accomplished. Step 14, I already riveted the nutplates to the F-1003D & E. Step 15, I riveted the F-1044B Angle, F-1044C Spacer and the F-1044D,E and F Angle to the F-1044A Forward Fuselage Rib as shown in figure 2.
Time about 1 hour because I had already accomplished most of the steps.
Priming Some of the Parts
The 1044A Forward Fuselage Rib to RivetedF-1044B Angle, F-1044C Spacer and the F-1044D,E and F Angle
