Brief Description: Section 26 Mid. Fuselage Ribs and Bottom Skins. Pa
Section 26 Mid. Fuselage Ribs and Bottom Skins. Page 26-5 Steps 5... 11 …. Step 5, Clecoed the F-1017A L/R Rear Seat Ribs and then created Rear Seats Rib Subassemblies and the Rear Spar Bulkhead Assembly then final drill all the #30 holes in common. Step 6, I disassembled, debured, removed the Aldine (with Scotch bright and 330 grit sand paper), cleaned with Acetone and then primed with DTM primer all the parts. Then Final Drilled #40 and dimpled all the 3/32 inch holes in the web of the Outboard Rear Seat Ribs. Step7, 8, and 9 … I clecoed the Left and Right Rear Rib and Seat Rib assemblies to the Rear Spar Bulkhead and then riveted them together using the rivets called out in Figure 2. Step 10 and 11, I clecoed the Outboard Forward Foot wells Ribs F-1015A L/R to the Rear Spar Bulkhead. Clecoed then riveted the remaining Ribs to the Rear Spar Bulkhead Assembly as explained in Figure 2. Time about 5 hours because of paint/priming time.
