/11/2008 .. Completed Steps 1 to 8 about the Trim Servo and associated Brackets as described on Page 11-8. Time about 2 hours.
Then I adjusted the Elevator Pushrod F-1091 to fit the 91.4 degree TEMPLATE as shown in Figure 1 and 2. Then threaded the jam nuts AN316-6 to the Rod End Bearing MD3614M to the Rudder as described in Figure 3 detail A. Next mounted the Rudder to the Vertical Stabilizer with the hardware shown in Figure 4. Checked the Rudder travel to 35 degrees as described in Step 5. Time about 3 hours.
